power steering rack, no pump
so my car came with a gsr power steering rack, but no pump. my steering feels really loose sometimes. would the fact that i dont have a pump be the cause of the loose feeling in my steering wheel?
Re: (guamie)
when we remove p/s pumps, we add a smaller fluid res., and a t - going to a loop from feed line to return on rack , this way rack stays lubricated, I've seen many without this but it seems to work for us
Re: (guamie)
Sounds like outer tie rod ends to me. Does it always pull to the same side? I had that start to happen to me, new tie rod ends and problem went away. Be sure to get it aligned after the replacement.
I had the same issues with a PS rack.
One thing you can do is remove all of the valving in the rack, fill it with grease, and put it back together. It will tighten up the feel quite a bit.
i recently installed tein HA'S, and the alignment is perfect. but it's still feeling "loose". maybe putting a power steering pump will solve it?
