Possible rod knock? b16
ok so i've been driving my car without knowing that my oil level was low. Now its making some noise, I've searched around and found some similar answer but I want to make it for sure that it is that. Now if it is, what should I do now? Im not about to waste money on rebuilt ($2000 @ redzone) ($2200 @ dnr). I was thinking of doing a poorman's typeR or go w/ b20 or lsvtec. Either way its going to cost alot of money. I need your input on this one so please help a brother out.
heres a short clip i took earlier
http://www.youtube.com/watch?v=qa_MrXuhRvo
Re: Possible rod knock? b16
doesnt sound liek its comin from the block. but i could be wrong. mine was doing tht and i put a new timing belt on on it and it stopped. maybe thats what it is?
1 Post
you could get another stop bottom end cheaper then $2000.... that sounds bad..id build it have a fresh block unless you are on a budget... my block sounded the same i drove it for 45 minutes trying to make it home and snapped a rod, had a big whole in the block...
stop bottom end? you mean stock right, If I was to get another stock I might as well go w/ ls or b20 vtec.
help anyone..
alright so heres another thought, should i just sell the car as is? cause I don't have the time to fix this anymore.
hey my b16 spun a bearing and the rod was knockin 2, so then i decided to put my b20 block under my b16 head and then about 3k miles off beating it, it has a rod knockin now 2,so i got some new high comp pistons, acl bearings, micropolished and balanced crank,and arp rod bolts, so if u go lsvtec do yourself a favor and get u some arp rod bolts
maybe a bent valve or something. how many miles on the b16? or maybe it just needs a valve adjustment really bad.
whats wrong with the b16 why you wanna ditch it? if you really want a different bottom end, get an ls bottom. if you go boost the ls will hold more boost better than the b20 due to the thin *** sleeves.
nope. never knew how to do to that anyways.
sirminder
07-25-2009 05:34 AM
madlion
07-28-2007 02:39 PM
