plz help.. code p1382 and p1381
hi guys,
My civic si 00 is hesitating between rpm 2k and 3k. Check engine light was on and the codes i got are p1382 and p1381 I have searched so long for the part number for the crankshaft positioning sensor with no result! A friend of mine said that the CMP sensor is inside the distributor and cannot be replaced alone and that i should get a new dist. thanks for ur help. If possible, please advise the oem part number of the sensor. |
Re: plz help.. code p1382 and p1381
No you absolutely do not need to change the distributor.
The part you're looking for is: Drum Roll.......... 37500-P72-A01 SENSOR ASSY., CRANK-TDC But I'd probably troubleshoot a little more before I start throwing parts at it. Not to mention, it's a $150 sensor and a bugger to change. If I recall correctly it's about a 3 hour job. |
He doesn't need to replace anything yet. He needs to follow the diagnostic flowchart.
Thanks guys for the info
Hi again,
As we found that the CYP sensor is not functioning anymore, I have found a used sensor from OBD1 distributor. Shall i buy this sensor or it will not work with my OBD2 distributor? |
Don't randomly replace parts. Test the CYP sensor wires between the ECU and distributor for a short or open. Also resistance test the CYP sensor and test it for a short.
Originally Posted by ribal_gh
(Post 49410315)
hi guys,
