pluggin heater core hoses
I'm not Rick!
ola. if im goin to rip out my dash and ditch the heater soon...can i just u-turn the heater core hoses together? and plug the ones coming from the motor? will this affect the motor at all? will it take away the cooling of the engine? [ATTACH]28978[/ATTACH]
Re: pluggin heater core hoses
Yes you can bypass the heater core, at least I have with no problems on my SOHC JDM D15B on my old car (the heater core valve was leaking). You will loose coolant and likely get air in your system while doing it, so after you do it a coolant top-off will be called for and you should bleed your coolant lines.
K7-1Ktrevor
01-11-2010 06:03 PM
Soda Popinski
11-07-2005 12:39 PM
