please help...new pistons/rods
ok i have a 2000 si. car is in the shop and i got news today that my pistons and rods are done for. a bolt came loose and messed up the pistons. so i am looking at getting the block bored maybe just 1mm over and getting CP 9:1 compression pistons....i am going to turbo the car in about a year or so....so please give me some opinions on what i should do...?
I'm not Rick!
Re: please help...new pistons/rods
do what your talking about. sounds like your headed in a fun direction. you can drive on 9.1 compression until you get that turbo put on but you still have to tune it and itl be slow until you put the turbo on..is this what your asking? get eagle rods too.
it cant get much slower than it already is...and yes how much is it going to be for me on average to get it tuned...just with pistons, rods, probably type r cams and minor other things.?
I'm not Rick!
well youl need a wideband unles you find someone that tunes with their own wideband. Dynos and shops will cost you about $300-800. Find some one that street tuneds and pay $100-200
i have an apexi neo...will that work? and also a few more questions. should i go ahead and get cams? if so which ones would be good for now and good for later boost?
Just 1mm? thats more than the max(.750mm), untill you go custom, I'm trying to figure out how 1 bolt messed up all your pistons, it must have been the cam sprocket bolt?, I think you need a new mechanic.
Not trying to be a dick but something sounds wrong, typically import pistons go .25mm at a time for oversize.
yea i see that now. i really didnt know much about the specs until i started searching...so i think im gonna have it bored .5mm over and run the 9:0:1 compression CP pistons with Eagle h beam rods. also looking at getting cams so what should i look into?
I'm not Rick!
get stage 1 turbo cams from blox or skunk2. if you get bigger ones that your idle will sound too cool and you need cam gears and good tune and a dyno. just get type r cams...i heard tony1 just uses cams just like type Rs
How much are you planning on boosting it? I would also look into getting better head studs and possibly a better head gasket.
The most crucial part of going boosted is getting a good quality tune... It seems odd that software could be so important but in all honesty proper engine management will make the difference between a fun boosted car and a blown engine.
yea i was looking at the skunk2 stage 1 turbo cams...when i do turbo my car i am going to have a 400hp goal. probably running a garrett t3/t4 60 trim. so i need cams that will work well with my piston/rod setup and everything. i am not looking to make power now i just want to go ahead and get the stuff done right since its broken down. and turbo will be after christmas hopefully.
I'm not Rick!
you can get 400hp on stock cams. bigger cams will help alot though. get the head slightly portd and valve job it. it helps alot. Xmas?! dude thats like forever
(X means Christ in Greek)
i know it man. im in college and im going to have to take out a loan or something to pay for this. hopefully i will get a job when i go back in august. but yes thanks for the opinions....i think i am just gonna go ahead and get the skunk2 stage2 turbo cams and get springs, retainers, and cam gears. that is, as long as they will be ok for a while without boost. i just dont wanna waste money on something and then have to change it out again. thats the reason i am going ahead and getting the 9:1 pistons.
Props on the Eagle rod choice!(CP pistons are good too), the only problem with running "racing" valve springs on a dd is that it puts alot of wear on your rockers where they come in contact with the cam.
The wear is even greater with a big cam(non-stock), my only concern is that by the time you install a turbo your rockers will be shot.
I would stockpile all the parts and install them all at once.
I understand your in a pickle because your car is broke, IMO buy a piece of crap dd, till your ready to build your honda.
be professional
oh no its not like i just want to take it out to pay for it. i have some money and stuff but i dont want to mess with my savings. i want to take out the loan in order to build my credit.
I was gonna mention taking a small loan will boost your credit...if you pay it back on-time.
The problem with the loan is from my exp. the car will break before you pay it off and you will be in the same boat but now you got a loan to pay.
