Please help: just to confirm......
Re: Please help: just to confirm...... (JV)
you tell KATMAN that this pic is ******* wrong and it cost me
just bullshit to fix, the pin locations for solenoid and oil are reversed..
I have wired a non VTEC car before and this pic is correct. What happened....?
trust me, i was working on a 94 teg LS...
and i double, triple, quadruple checked it, and still no vtec.
WHY>>>>?????
because Katman has the vtec solenoid at D6 when its VTEC Solenoid A4
and he puts the oil switch at A4 when its VTEC oil switch D6
to http://www.hasport.com for the CORRECT wiring... i wish i had seen the website b4 i saw that pic.!!!
http://www.hasport.com/92-95%20_ECU_comparison.htm
So does your VTEC work now.....?
i had to reverse the wires in the bay to get them wired
identical to the hasport site, now she works fine,
the wires from the ECU to the connection were
red and green so i knew for a FACT
that it wasnt a (Jesus all these black wires, "what goes where")
Re: Please help: just to confirm...... (Giuseppe)
Re: Please help: just to confirm...... (infamousRRH)
yup friend learned the "katman" way also.
aww you should have at least told him, so he could have fixed the pic
to ensure others like me) dont get all aggravated while doing wires..
regardless, its a simple fix. good luck guys
[Modified by Giuseppe, 9:54 PM 6/15/2002]
you TOO??
you TOO??
Re: Please help: just to confirm...... (Katman)
ok updated my OBD1 vtec wiring schematics.....check it out:
[/QUOTE]
SWEET, good job, i guess you're still Da Man>!
edit: katman, do i get a prize for pointing out the mistake?? do i ...do i...huh.???
[Modified by Giuseppe, 6:32 AM 6/18/2002]
Re: Please help: just to confirm...... (eg6ajk)
Which 2pins on the vx that you need to repin? let me know, thanks.
All I did on the O2 part is plug it into the GSR engine harness and that is it.
Tony, you get nothing but this, engine swaps simply hurt
[Modified by eg6ajk, 7:22 AM 6/18/2002]
no more swaps for me...im DONE.!
