PLEASE HELP ASAP BLEEDING CLUTCH MAST.CYL
ok i have replaced the clutch master cylenderin my 94 si with gsr.. everything went smooth till i bled it out it still wont go into gear..?? wtf..
1) does the car have to be running to bleed the clutch? im guessing no just on the on position..
2) i have adjusted the piece that bolts to the clutch pedal arm all the way out to allow the most throw( im thinking) and still no go.. is this right or do i need to screw the piece in?
3) im understanding that the only bleeder fit is in the front and thats it am i correct.. what else am i missing ???
PLEASE HELP!!!!!!!!!!!!!!!!!!
THANKS
BRIAN
THANKS
BRIAN
Re: PLEASE HELP ASAP BLEEDING CLUTCH MAST.CYL (hatr-aid)
ok this is what i do
1. i fill it up
2. put a 8 wrench on the blender valve
3. go inside and push the pedal in and out like 7-10 time
4. get out and open it up so the air bubble go out
5 tighten it up and repeat 3-5
and no it dont have to be running plus youll burn ya arm
1. i fill it up
and it will take some time for the pressure to build so dont flip or you can push the clutch in/out real fast
thats how you bleed the slave. you need to bench bleed the master cylinder. loop line back to reservoir
hndacord02
02-27-2007 07:17 PM
KRAP DIVAD
09-04-2005 05:10 PM
