Please help
Can somebody please help me. I have a 95 honda civic dx, I just put a new block in it but now it wont start all the way up. I cant get any spark from the plugs, i cant even get a spark from the coil, ive tried 3 different ones(not new)but still cant get anything. So i got my test light to make sure its getting power and it is, but still no spark. Somebody pleas help thanks.
Re: Please help
Use a multimeter to ohm test the coil and to check whether 12.5V reaches the distributor.
Re: Please help
Originally Posted by muellersfan
(Post 51947194)
Re: Please help
The voltage test would be red on + (the black-yellow wire going into the distributor) and black on ground.
I have found ohm tests of a coil to be fraught with false negatives (they tell you the coil is good when it is actually bad). |
Re: Please help
Originally Posted by mk378
(Post 51947342)
I have found ohm tests of a coil to be fraught with false negatives (they tell you the coil is good when it is actually bad). mk, how do you perform the coil Ohm test? Perhaps we can resolve this minor dispute with a discussion. [I really don't expect a response because mk typically will not engage in forum discussions. :(] |
