Place Racing EK mount review.....
My B18 ripped through my stock upper drivers side mount like it was paper so I did a little research and decided to replace it with the Place Racing EK drivers side poly mount that I purchased from jdmhondaparts.com http://www.jdmhondaparts.com/p...1.jpg. Replacing the mount was easy. I took off the 4 bolts from the old mount, put a wood block on my jack and lifted up the engine a little. With the help of a friend and 2 crow bars we finagled the old mount out. The new mount bolted up perfectly. It took a while to get the engine lined up to get the last bolt in but with the help of a friend and 2 crowbars anything is possible. Total time to complete was about 30 minutes. I started the car up and noticed a difference right away. The car hums and vibrates but nothing I won't be able to fix or live with for the difference it made in the car. My civic is like a totally different car now. I can't believe how much one little mount changed the entire feeling of the car. It is so much smoother, I can't even describe how different the car feels. My next step is to order the ES drop in mounts. I can't wait to see how they add to the feel of the car. For $140 the Place Racing mount was worth every penny, it's like I have a new car again.
i got the mount also, it does vibrate more which sucks but its worth it. my friend swapped his car a month ago and blew 2 oem mounts already. when it blew the 2nd time his engine went threw the hood.
Re: Place Racing EK mount review..... (Witty)
i had the same thing happen to my driver's side mount from my b16 swap, but went the way of hasport.
https://honda-tech.com/zerothread?id=512504
i have the es inserts also, although i had them before the hasports. vibration will increase, but probably not much worse than it is already. with the inserts (including rear) and the place mount, i doubt you would need the j's racing thingee. my motor doesn't budge.
Re: Place Racing EK mount review..... (todaCspec)
i too got this mount for an oem replacement. And he's right it vibrates like crazy at idle. Anybody else have any info on this?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by todaCspec »</TD></TR><TR><TD CLASS="quote"> J's-racing engine dampner. </TD></TR></TABLE> Thanks, Mike D
Tie Ee Fei
64
01-17-2019 04:45 PM
USDM EG
03-23-2008 08:41 AM
builthatch
04-19-2007 06:20 PM
