Picture Request
Picture Request SRS system civic 94+
Ok, I am trying to restore a '94 hatch that was stripped, and I am in the process of restoring.
(when I mean stripped, I mean stripped.)
I have run into a snag and I need a pic to help clarify what I need. Ok, I am trying to re-install the SRS system. I still have the SRS computer, but the sensors were missing. I do have a "parts" vehicle which is a '92 but compared to how they mount on the '94 is completely different. The pic I would like to see is either a photo of the 94-95 srs computer plus the harness and sensors or a pic of 94-95 civic that shows where the sensors mount up and what type of bracket I need.
Thanks
Modified by CHK4TIX at 10:11 PM 1/22/2007
Thanks
Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">yeah bump man. gl that **** is stripped</TD></TR></TABLE>
Thanks, I have mage some good progress on it but as I said I am confused about the srs mounting. I guess i could just leave it out but I really dont want to do that.
Re: (CHK4TIX)
your 92 parts car did not have SRS, that won't work for you. You need a 94 up to get all the parts necessary for both driver and passenger SRS because the 93 only had driver side airbag.
Re: (JokerX-1.6T)
ok this is what i found so far.
this is the srs system for a '92 in this picture shows srs sensors, (labeled #1)
But in the "94 it doesn't show these at all. Are the sensors in the srs ecu? does anyone know?
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">hey did you find that on craigslist?</TD></TR></TABLE>
the car? no it was one I have owned for a while, then someone decided they wanted it more then I did.
Re: (CHK4TIX)
did u try a manual or maybe alldata program??? just an idea... obviously u got that pic from some manual but maybe a different one. I use all data at work i could try if u want?? Just give me the info
Re: (YellowB16a2)
i just had 2 cars down to that point (completely stripped) and put them back together. man i knew i shoulda grabbed some pics.
i dont rightly remember what goes where
bump for you man, good luck with it (your at the pain in the *** stage)
Re: Picture Request (CHK4TIX)
ok after some more research I found the info in the pic. It seems that the sensor for the srs system in the 94+ is in the srs ecu itself. So this is why I couldn't find where to mount the sensors. Does anyone have a cheap 94+ srs harness?
