Performance Radiator Fan?
dose anyone out there have one? im thinking about getting a performance fan to bolt on where the air conditioning unit use to be on my EG. someone told me that if i have my stock on and hook up a performance on also to where its always on, it keeps it alot more cooler should? has anyone else dose it?
Re: Performance Radiator Fan? (924doorEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 924doorEG »</TD></TR><TR><TD CLASS="quote">dose anyone out there have one? im thinking about getting a performance fan to bolt on where the air conditioning unit use to be on my EG. someone told me that if i have my stock on and hook up a performance on also to where its always on, it keeps it alot more cooler should? has anyone else dose it?</TD></TR></TABLE>
not sure how much cooler it will be. oem fans kick on when the car hits a certain temp. i guess it might help since it's running constant, but what do you do if the motor burns out?
if you want to help keep you car cooler, there are other ways, cheper ways.
you can get a thermostat that opens at a lower temp. there are also radiator caps and temp swiches that do the same. other than that, there is no other significance or performance gain from it. the way you are setup now is just fine.
save your money!
save your money!
1baddcivicsi
10-03-2006 04:55 PM
crashtest Sonny
16
05-07-2004 10:11 AM
