People with ZEX 59300 cam, read HELP!!!
I feel a flat spot or lag or hesitation or something at 1000-3000 rpm
OK i installed my zex 59300 cam and i adjust ign timing, it's right at 16btdc, the cam timing is stock and it lines up with the white tdc mark.
NOTE: somehow i had to adjust my dizzy to max advance to get it to stock timing
NOTE: my engine is the d16y8 using zex 59300 cam with stock z6 cam gear
When i FLOOR it or even 1/2 throttle, the car makes a weird sound like it's struggling... and it feels really slow, slower than stock cam and kinda slower than if i don't floor it.. this is from 1000-3000 rpm and is more prominent in 3rd and 4th gear. i can still feel this in all gears.
What is wrong? is it my valve clearance? maybe too tight? No one really told me how to adjust them properly. i did it 0.005 in and 0.007 ex but i do'nt know if i did them right.......
the way i did them was i turn to tdc for the piston i'm working on... (i pray my cam timing is right, i think it must be since the stupid white mark lines up when my cam gear is lined up on the block as well).....
after i get tdc, then the piston i'm working on, the rocker arms have free play, i can move them up and down to a small degree (is this correct?)
then i push them UPWARDS against the camshaft, so there is a gap between the valvestem and rocker arm. then this is the gap i adjust right?
i THINk this is right since if you just put the feeler guage in between the stem and rocker without pushing it UPWARDS, then it's going to be wrong right?
help! i think something is not right.... !!!
i don't think people with this cam have this hesitation or loud sound. just feels lag
Re: People with ZEX 59300 cam, read HELP!!! (2000vsm)
I installed this cam in a y8 last weekend. You need to adjust the valves to i think .007 intake and .009 exhaust and you should advance the cam gear 4 to 5 degrees because you are using a z6 cam in a y8 head and the z6 and y8 cams are different.
Re: People with ZEX 59300 cam, read HELP!!! (SOHC_MShue)
I have the Crower stage 2 in my y8. I am going to get the car dyno tuned because I have CRAZY AMOUNT OF BOG. If your prob is the same as mine, it is my VAFC tuning, I need to get my fuel map tuned. Wanna talk rich? I burn 1/3 of a tank of gas a day, thats right. Hopefully tuned next week
Yeah, you're telling me. I just hope that it is indeed my VAFC's tuning that needs it. I'm not ready to fork out $400 for an MSD set-up right now.
Solbros Owns Me
Re: People with ZEX 59300 cam, read HELP!!! (low-tech assassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low-tech assassin »</TD></TR><TR><TD CLASS="quote">if your using the z6 cam in a y8 head you have to advance the cam 5* to equal tdc. </TD></TR></TABLE>
listen to this man
listen to this man
mycvc8u2
11-13-2003 01:51 AM
