pcv valve 98 honda civic ex
I know this may be stupid to ask but in realitly there is no such thing as a stupid question. Where may i find my pcv valve for a 98 civic ex. I know that I can get the part its only $2.50 were i work at autozone but having trouble finding it. And also does it cause a problem with gas mileage or anything like that? And would it cause an idleing problem?
Re: pcv valve 98 honda civic ex
you can always remove ur throttlebody and its much easier to remove it from there also just throwing it out there 2.50 for a pcv u get what you pay for
honda oem PCV was like 15 but it makes you sleep better at night
It is part #3 below.
A failed PCV valve can cause MPG to go down and oil leaks at seals such as the oil pan gasket. I replace mine every 100k miles. I buy only OEM PCV valves. I clean mine about every other oil change with PB Blaster. I would not expect a bad PCV valve to cause an idling problem, apart from running rich.
ya thanks for all da info i appreciate it alot. I did replace the pcv valve, and the fuel filter, and now its like jumping everytime i put it in 1st and go to take off it acts as its jumpin cuz of out of timing but i knw its not. Was told that it could be a injector try to clog.
dishjuarez
01-31-2012 05:46 PM
