Password JDM radiator cooling plate....is it worth it?
Is the Password JDM radiator cooling plate worth the $70. Does it make a Difference? Anyone running it right now......what's your opinion
Darth ModerVader
Re: Password JDM radiator cooling plate....is it worth it? (Delano5050)
Chances are that your cooling system is perfectly sufficient for your current setup. If it isn't there are other cooling upgrades that will have a more significant impact that this part. Either way, it's not terribly expensive and some people like the appearance that it provides. If I were going to perform a modification of similar cost, I'd probably pick up or construct an earthing kit instead.
Ek Forever y0!
Re: Password JDM radiator cooling plate....is it worth it? (sicones)
Unless you have a ridiculously cool track car, then it's not likely to be a worthwhile upgrade.
Do you have cooling issues from oil getting too hot heading to the grocery store? If not, then don't get it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">it's just for looks, IMO worth $70...no</TD></TR></TABLE>
Agreed.
That $70 could be put towards an upgraded radiator or fan if you were running into cooling problems that were radiator/fan related.
Agreed.
^^ X2, just looks. Invest in somehtng more worthwhile if you are having issues, such as a better fan, aluminum rad, or even aftermarket engine coolant (cant remember names off hand)
Re: (instrument)
not worth it, save that 70 on something useful man. Lots of junk out there because its just marketable.
I have one, I did not buy it. I got the weksos one new for free, through a purchase of parts from a cool seller. I could not believe this was $70-80+.
I really dont see the function of this besides placing a cover over the ugly can-sprayed radiator part. It would look much better if i can have it over on top the front bumper where it hinges off of, instead of having the plate inserted between the rad support and the bumper.
Re: Password JDM radiator cooling plate....is it worth it? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Chances are that your cooling system is perfectly sufficient for your current setup. If it isn't there are other cooling upgrades that will have a more significant impact that this part. Either way, it's not terribly expensive and some people like the appearance that it provides. If I were going to perform a modification of similar cost, I'd probably pick up or construct an earthing kit instead. </TD></TR></TABLE>
QFT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Unless you have a ridiculously cool track car, then it's not likely to be a worthwhile upgrade.
QFT
Do you have cooling issues from oil getting too hot heading to the grocery store? If not, then don't get it.</TD></TR></TABLE>
QFT
QFT
Re: Password JDM radiator cooling plate....is it worth it? (B16b-EJ8)
Im a noob... what is QFT?
If I were ever to purchase a "cooling plate" it would be to take it to an engineer at my work and have him CAD a similiar design so that I could send it to our machine shop and produce a handful of them for myself and friends.
Re: Password JDM radiator cooling plate....is it worth it? (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">Im a noob... what is QFT?
I used to think it was "Quit F****ing talking" but after getting in an E argument i learned it was "Quoted for Truth"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">
I used to think it was "Quit F****ing talking" but after getting in an E argument i learned it was "Quoted for Truth"</TD></TR></TABLE>
kommon_sense
16
06-20-2008 05:07 PM
kun3racer
10-13-2004 10:35 PM
