passenger window problem, need some help
car is a 99 civic ex, i bought the car and the guy told me that the passenger window motor was blown and needed to be replace, so i replace the motor and regulator just because its easier and idk if the regulator was bent which caused the motor to go, but anyways i replaced the motor and regulator and it still doesnt work, i checked the two 20a fuses under the dash and the 40a under the hood and there both fine, i havent checked the switch cause i didnt have a test light on me at the tme, is at work, but i was wonderin if the passenger switch is blown, will it not work from the master switch as well? becaused it doesnt work from the master switch, or vice versa. just wud like to here if anyone has run into this problem
Re: passenger window problem, need some help (moosepoop21)
a test light would be best if handy as you said. i know if the pass switch is not hooked up then the circiut is not complete. maybe if the switch is bad then the circuit can not be complete. in turn not workin thats my 2 cents lol could be wrong.
best think make sure power is goin to the reg and switch on pass side. good luck
