passenger side window
i bought a 99 honda civc ex about couple of months ago and my right side window is rolling up real slow. is there anyway i could fix this problem? this is really pissing me off!
Re: passenger side window (myhonda2slow)
make sure, those rubber rails arn't geting cought up on anything, if they arn't and it still does it. then it could be your motor.
i have a similar problem... i have an 01 civic and my passanger window wont go down.. i replaced the window motor the power switch .. their is even no sound when i press the switch... i need a relay switch
Putting lube will help the problem of slow rolling up. However on the 01 with no downward movement, you most likely have a broken wire in your window harness. I had the same problem with mine and I had to replace the harness. You will be better off splicing somewhere under passenger seat because changing the whole thing is a pain in the butt.
misoshiru_akira
01-31-2007 02:14 PM
