Passenger Side Axle Install Question
Hey guys I got a silly question again ...
I'm installing Gator racing axles and im not sure if there supposed to be a gap on the passenger side by the transmission. I'm pretty sure I've whacked it in there all the way,but I'd like the opinions of that you guys think.
He are some pics, the circle in red is the "space" in question. I'd say its no bigger than 1/4" or less.
Thanks in advance!
Thanks in advance!
Re: Passenger Side Axle Install Question (FredoSP)
that axle looks like it in ok.. it late and cold outside or i would go check mine.. but im pretty sure mine looks about the same
Re: Passenger Side Axle Install Question (hybrid94Si)
I think that is fine. Mine has a little gap just like that. If it was closed all the way, how would u stick a pry bar in there to take out the axle ya know.
it popped in right? it looks on but I am picky about doing things right the first time good luck bro
Re: (95turbohatch)
its fine,..but next time,..instead of worrying if you did it right or not,..for passenger side axles,..always try to notice the axle click or pop in when installing it,..once it clicks or pops in,..its in
I hope you didnt really "whack" it. Well depends on where you hit it but you could damage the boot.
The axle is all the way in though.
Re: Passenger Side Axle Install Question (sting94112)
Back from the dead, any opinion on my problem ?
https://honda-tech.com/zerothread?id=1069988
Well I was changing the axle on my other rex and I ran into this problem, the new axle and the old axle do not seem to want to seat in the trans all the way. Here are a few pics to explain what I'm talking about. The old axle and the new axle sit the same way, the only problem was the old axle joints were shot, so just maybe everything will be ok.
Old axle, see the dirt ring, this shows how far the old axle was seated in
Another shot
And here is the new axle seated, the same as the old one was.
Before people say hammer it in more, I hammered it in as much as its going in. The previous owner of this car ghetto rigged everything on this car, so I'm sure he tried replacing the axle before and messed something up. Just wondering if anyone ever faced a similar problem, if so what was the solution ?
Another shot
Location: hittin corners so hard you can taste my rims..
Re: Passenger Side Axle Install Question (90blackcrx)
look at 90 black CRX's thread again.. i elaborated big time.
shadohconspiracy
11-03-2007 02:22 PM
