pass axel wont budge!!!!
hi i need help my pass side axel will dot come out ive tried the screw driver but it wont come out please help!!!
Re: pass axel wont budge!!!!
remove the driver side axel and use a LONG and thick screw driver and a hammer to push it out.
just dont hammer it TOO hard
DUH! read to fast. did you try it like that??
can you really do that!!! if that is the case then gaddam im pissed cause i tried every thing for two hours!!!
can you really do what???
and if you talking about what i said, no you cant f up something unless you f up. like if you dont hit the axel. just make sure you hit it in the middle and the long screw driver isnt too wide. make sure it ONLY hits the axel
i didnt write back as if you were an idiot.
if you took it that way i apologize. but it was not meant that way.
and your welcome. let me know if it works
The best method I have found is using a ball joint separator (pickle fork), snug it up between the axle and the transmission and give it a quick strong pull or push and they come out really easily.
Yea there we go i couldnt think of the name, pickle fork, yea like saywhat said that is the best method of removing the axle, now to put the new one in is gonna b a b***h as well.
PrettyMuchBoned
04-24-2014 07:20 AM
RC000E
Welding / Fabrication
15
09-26-2007 09:40 AM
Sassafrass
04-24-2003 11:40 AM
