Part number for starter cut relay (PIC included)?
1 Attachment(s)
Included in the pic below, boxed in red is the Starter Cut Relay. I've taken this printout to Autozone and Oreillys, along w/ the relay itself. None of them could figure out a matching part, mostly because their system does not include a starter cut relay (or so they told me). I am guessing that I may need to purchase it from the OEM
Any help in determining an OEM part number for this relay, or a number I can take to an automotive parts store would be greatly appreciated. Thank you in advance. BTW, I have a 1994 Honda Civic EX, manual trans...bone stock. Attachment 459966 |
Re: Part Identification (PIC included)
If I am not mistaken, that is part of the factory alarm system. Does this car have a factory alarm on it? There are things listed in that diagram for ALL makes of cars. See the daytime running light relay? Thats canadian, but its still listed. Just because its there in the picture doesn't mean your car is equipped with that item. Whats the reason you are seeking this relay anyways?
Because my car won't start. I've replaced everything except for this (starter, ignition, clutch switch), and it still wont start. I searched my manual and am assuming that this is the last piece to the puzzle. Yes, my car has an alarm, no I don't know if it is factory or not. I've never used the alarm, and the person who sold it to me never used it, so I am not sure whether it even works. I've tested the relay and it is bad, and since I can turn the starter by wiring 12v+ straight to the starter, then it must be this.
Unless you have other suggestions, I don't see what else to change. |
It's rare for the starter cut relay to fail. Have you ruled out the safety switch at the top of the clutch pedal and the rubber stopper that presses on the switch?
Also, if you say this is part of the factory alarm system, and i have it on my car, wouldn't that mean that my car came w/ a factory alarm? I'm no sherlock homes, but i would assume it does.
Originally Posted by RonJ@HT
(Post 43252842)
1 Attachment(s)
1 Attachment(s)
The starter cut relay is the same as the A/C compressor clutch or condenser fan relay, so you can try swapping them.
Attachment 459963 |
(Post 43252884)
Is the rubber stopper intact (see red arrow).
Does the relay test bad? I tested the relay and it was bad. |
U sure? the numbers on them arent the same. I'll try it though, dont see where it could go wrong. Ive tried everything else.
Originally Posted by omgwtfbbq
(Post 43252942)
(Post 43252849)
You didn't post in your original post if you had the factory alarm so I asked. If that pisses you off then either don't post on a public forum or include more information. Quite often you will find things on the car that are put there in normal production and simply not used until the rest of the components are added. I don't see how you haven't thought to find a matching relay on the car (such as the A/C one listed above) to swap in its place. This would rule out the relay as your problem or identify your issue. I guess you aren't sherlock holmes as you said earlier. |
Originally Posted by Hybrid96EK
(Post 43253536)
This just seems like a smart ass response. Maybe I took it wrong...
(Post 43254070)
didnt mean it in a smart ass manner. This relay is labeled differently than the others. Didn't want to swap them out and then **** something else up. Anyway, Im gonna try it out and i'll let you guys know. Appreciate all the help guys.
Re: Part number for starter cut relay (PIC included)?
You can swap it with your horn relay, too -- real easy because that horn relay is right there attached to the right side of the fuse box.
(Post 43252835)
k i found out what mine is..it is the clutch pedal switch A. It is not a relay! i push on the button on the switch A and it starts easy. i think the part that makes contact isnt making contact with that switch cuz the rubber insert corroded and fell out. Honda puts a rubber insert in a hole that is suppsed to make contact with that switch..mine being an older car probably wore out...idk why honda even put an insert instead of just making the whole think flat and metal. well found my prob hope it helps you guys out.
(Post 43254070)
And this fixed itself or the op pushed off a cliff. Come on guys post when you get it fixed... Geezz |
