Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda: How to paint your engine cover
Step by step instructions for do-it-yourself repairs.
Painted Valve Cover (easy DIY)
#176
Re: (cardr)
I am going to be repainting my car in summer and thinking about painting the valve cover the same color. I have black wrinkle paint but everyone has that now. Has anyone tried this before and got good results?
#177
Re: Painted Valve Cover (AlphaQup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup »</TD></TR><TR><TD CLASS="quote">
I'm not too sure if there was a color code but, here are the can pix I got from summitracing.com:
**edit** actually the paint code is listed on the can pix below
red
or black
props for some sick covers
I bet you had fun scuffing n sanding that **** huh? </TD></TR></TABLE>
anybody know if kragens or autozone has this paint plus in all colors
red
or black
#178
Re: Painted Valve Cover (dApEkLuV)
I don't know if kragen got it but the way I did mine was with spray paint from home depot, its called textured. Buy it in black then spray what ever color you want over it since color range with the textured stuff isn't large.
#179
I found that autozone can order the red wrinkle paint. Also make sure that you use a white primer not a grey. it makes the red brighter.
#180
I have ordered it at autozone but that was the red and black. I use to get the blue and yellow at an autobody supply store. Sadly you have to have a painters license to purchase for this store but find one in your area and just ask if you have to have a painters license to purchase and if not there you go. I will say it is spendy like $8.00 a can.
#181
Re: Painted Valve Cover (easy DIY)
Would a wire wheel work for scuffing rather than sandpaper? Just seems to me like that would work just as well if not better.
#183
The brass wheel might do the same on the valve cover doing the opposite of what you are out to do.
Steel wire wheel would probably work well.
#185
That way if it doesn't it's not in a visible area. Will require pulling your wheel off to test but if it works, could do a nice polish job.
