P54 bracket????
P54 bracket????
can someone show me a pic of a p54 bracket?
i see a bracket on y motor that says p54
is it the one right under the power steering bracket? the ac pump tensioner = P54?
Re: P54 bracket???? (Hybrid95CivicEX)
yes that is a p54 bracket. I had to buy one for my ej8 to put my a/c back on after my motor swap. AZ was too hot.
i will have to look again, as there are 3 brackets in that area.
the power steering support.
under that is the "p54" bracket
then under that is the motor support/torque mount bracket. (part # unknown)
gotta take a closer look:p
thanks fellas.
thanks fellas.
Re: (CivicSiLS)
Hi guys.
The P54 is off a USDM Del Sol (maybe others, but that's the one I ordered). I had to use the P54 to use my old AC from my D15 on the B16... the other AC mount- the P30 bolts onto the motor fine, but it didn't line up on the compressor, thus I could only manage to screw in about 2 bolts. I kept ordering the Del Sol mount (P30) but they kept snapping- due to uneven support of the compressor, but finally found that the P54 was the one needed if you plan on using your older compressor on your B. Hope this helps, it was a frustrating experience for me!
