P2P ecu help!!!!
318 Curves, 11 miles
Re: P2P ecu help!!!!
yes, we need year of car, year of engine, which engine, etc...
Have you tried putting the original ECU back in? Does it start on that one?
so he's doing a mini me head swap using a z6 head, or he has a complete zc motor (like a d16a6 or d16z6) either way, i dont know aof any obd2 zc motors. i thought they were only obd1 motors. what wiring harness is he using? the p2p is a obd2 ecu, so it wont work with a zc wiring harness.
(edit) didnt see previous posts when i was writing
he makes conversion harnesses/jumpers. he used to make em for jhp. he pretty much is the go to for questions about wiring, ecus, frankenstein stuff.
search his username
search his username
Bro, ideally you want to match ECU's to your head. I have a mini me (y7/y8) in an 97 Cx so I have a P2P. They make harnesses to convert to the OBD1 if that's the year of your head which is plug and play, it's not scary or hard to do.
its not a y7 block you should read the posts before posting and the way he has it now it should be just a plug and play
Renegade
09-08-2003 06:37 PM
