p28 vs p72 for h22a? which 1 better for better performance?
Re: p28 vs p72 for h22a? which 1 better for better performance? (tr0n9h)
Well if you dont run a p13 you wont get the full potental.
P28 is for SOHC how is that going to benefit you?
P72 is for dual butterflys, do you have that?
Re: p28 vs p72 for h22a? which 1 better for better performance? (Luserkid)
i know that p72 control the butterfly, but i heard that when p72 and p28 is chip for h22, they both perform similar. im not sure just wondering
P13 is not compatible with hondata and has very limited tunnig capabilities. Both th P72 and P28 have to be tuned to run an H22 correctly so in the end they are exactly the same. In the begining the p72 will cost you about 100 bucks more!!
Re: p28 vs p72 for h22a? which 1 better for better performance? (cb7-R)
how come the p72 worth alot more then the p28? is it because it rare?
Because the stock motors that they run. GSR > EX/Si.
In the end, P28 is better choice, cost less, and has EXACTLY the same capabilities.
Re: p28 vs p72 for h22a? which 1 better for better performance? (diegoaccord)
I'm running a chipped p28 with an h22 chip in mine right now....disabled the egr and the iabs...runs like a champ..check the sig....
The GSR p72 has the knock sensor board, the p28 doesn't. So you will lose that, but if you can find a p30 and chip it, then you still run with a knock.
Re: p28 vs p72 for h22a? which 1 better for better performance? (xv53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xv53 »</TD></TR><TR><TD CLASS="quote">I'm running a chipped p28 with an h22 chip in mine right now....disabled the egr and the iabs...runs like a champ..check the sig....</TD></TR></TABLE>
what iabs?what it stand for?
ilovejdmhoes23
01-20-2007 11:52 PM
u2civic1
04-01-2003 09:54 AM
