p28 mini problems
p28 mini problems
Hey, for some reason the search isnt working and I need the pinout for a p28 ecu.
the car is a 95 cx with a d16a6 block and z6 head. Using p28 ECU, Idles fine, no codes, but when you go to hit vtec at around 6k it throws a code for vtec solinoid. The wiring has been checked countless times and the only thing I can think of now is maybe the pinning got mixed up or the solinoid is bad. I have the solinoid run to A4 and the oil pressure switch run to d6
anyone have the same problem?
Modified by StupidSlowCRX at 11:34 AM 11/7/2004
Modified by StupidSlowCRX at 11:35 AM 11/7/2004
Re: p28 mini problems (StupidSlowCRX)
I switched the pins and now its throwing a code for the pressure switch. Vtec doesnt engage and it wont rev past 6k RPM.
any help is good help
pureclass69
03-14-2011 03:05 PM
SiR Inspired ED7
11-02-2008 05:49 PM
Houston Hatchback
08-24-2002 06:03 PM
