? P28 with h22 swap, will it run good
Old 08-01-2004, 08:41 PM
quaker's Avatar
Default ? P28 with h22 swap, will it run good
i have an obd2 h22 swap in my 94 hatchback, will it run good with a stock or hondatad p28 ecu, or does anyone suggest any others that don't require repinning of the harness
quaker is offline
Old 08-01-2004, 09:03 PM
blackdelslo's Avatar
Default Re: ? P28 with h22 swap, will it run good (quaker)
If you have a stand alone fuel management system such as hondata why would it not run right? Isnt the p28 for a 1.6L sohc vtec motor? So your going to use it for a 2.2L dohc vtec motor? It will run but not to its potential at all.
blackdelslo is offline
Old 08-01-2004, 09:06 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quaker &raquo;</TD></TR><TR><TD CLASS="quote"> will it run good with a stock</TD></TR></TABLE>
No, the ignition and fuel maps are not a engine the size of a h22a. You will have to chip it or piggy-back (hondata, uberdata). Chips are good if you just want to "plug and go" but a hondata/uberdata will yield more HP if tuned right.
Turbogixxer is offline
  • Ask a Question
Question Title:
Description:
