p28
p28
ok i did a search and found nothing. well heres my question. what is the spec on the p28 ecu. what is the crossover point for vtec? what is the redline at? and is the fuel curves different from a obd2 ecu? will there be any difference in performance wise if i used a virgin p28 ecu in my obd2 d16y8 motor compare to the original ecu that came with the ecu?
Solbros Owns Me
Re: p28 (PROJEK98)
performance should be the same, if not a little better with the p28. I think the p28 puts out a total of 23 degrees timing total, if I'm not mistaken.
VTEC is 4800, fuel cut is 7500. It's a great ECU. I know many people running H22 engines on a stock p28
