p06 running a d15b8 WTF
so im running a p06 ecu on a d15b8.. my p05 went bad so i had to order a newer one..and the dumb *** people send me a p06...i know this ecu is used for a 16valve motor...but what would anyone recomend me to do...im kinda short for money and i dont have any other vehicle to get me to work and back....if anything will this ecu hurt my motor
Re: p06 running a d15b8 WTF
its gonna run a little bit rich and will actually give you a slight bump in power. the B8 is geared more towards economy then the B7 if I remember correctly. teh B8's an 8 valve isnt it?
yeah the b8 is a 8 valve and the b7 is a 16 valve...the car does run but it is really hard in the lower rpm...deff feels like i got some hp gain...do you think it would run alot better if i got the 16 valve head put on it...also is it gunna hurt my motor if i keep running it like this for a little longer
if you put the 16 valve head on it you will gain prolly 10whp, the 16v head flows betyter and has double the valves, and theoretically double the air has teh chance of going in. get the 16v head and intake manifold, and you will be like a normal d15b7
Mr. Badwrench
po5 is a single wire o2 isnt it?
the p06 is a 4 wire. you may have an issue with a cel for an 02 heater also.
i have used a p06 to run a b16 it can be done.
OP take a look here. this thread is about going d15b8 to a d15b7. I guess it requires more then just a head and intake manifold. if you change teh head alone, you would be fine, but the B7 intake manifold and throttlebody will give you best performance in relation to a true B7, but it requires a bit more effort. I do have some extra parts, I will read this thoroughly as well. My extra B7 thats going in doesnt have a lot of parts, so i might not be able to help much
http://hondaswap.com/engine-building/d15b7-d15b8-32168/
the car runs nasty as **** right now im just looking for a cheep fix..i just be thinking if i put the 16 valve head on it..it might run alittle smother...trying to save the big $$ for my b18 im putting in it i just need the car for a dd right now and all it is doing is pissing me of...it wont idle an its own but when i put my foot to down it goes just fine...so im looking for a head and intake manifold for the time being...as long as i can drive it around and not get wiplash from it hit all weird im good...im located in ILL what u want for the head
by putting the 16v head on there, you will be running the setup the ecu was designed for
the intake manifold you have will work fine, its just a bit limiting.
garrett2601
03-31-2010 09:30 PM
KdiZzLe
03-09-2007 06:02 PM
