p06 ecu code 0???
Old 03-17-2013, 12:50 PM
Zen_Life's Avatar
Default p06 ecu code 0???
Okay, I've ran into a slight problem with my car and I'm hoping that someone here can help me out. Here's my problem with my 95 Civic CX:
Last Thursday I parked my car after going on a few errands, went inside and went to sleep. When I woke up on Friday, I went to my car to leave and all it did was try to start, not actually fully start up. So in a slight panic, I went and bought plugs, wires, new cap, rotor button, fuel filter, and did a tune up on it thinking that the wires that were on it were faulty cause the car had sat up for a few months. Still nothing. So as advice from a friend, I cleaned all my ground wires, cleared the code 14 and 41 by replacing the IACV and the O2 sensor with ones I either already had or from the junk yard. My dad tested all the components inside the dizzy and they were all receiving power, just nothing was leaving the dizzy. We jumped the connector by the ECU and all that happens is that the SRS light continues to flash and the CEL just stays on. Is this a sign of a code 0 meaning my ECU was fried? Mind you also, the fuse for the ECU was blown and was replaced. Please toss any ideas out and I'll tell you if we have tried it or not.
If talking on the phone is better, feel free to PM me asking for my number. I have no problem giving it out when it deals with fixing my car.
Old 03-17-2013, 01:11 PM
Seagull Management
94EG8's Avatar
Default Re: p06 ecu code 0???
Is the ACG fuse under the dash blown? Does the fuel pump prime?
Old 03-17-2013, 01:40 PM
Zen_Life's Avatar
all fuses are good and yes the pump primes. and the main relay works.
Posted from Honda-tech.com App for Android
Old 03-17-2013, 03:03 PM
mimog3's Avatar
are you getting spark? if not you might want to check your ignition coil
Old 03-17-2013, 03:16 PM
Seagull Management
94EG8's Avatar
Try a known good ECU if you can.
Old 03-17-2013, 03:28 PM
HondaTom87's Avatar
check the plug you jumped to get the codes again your srs light should only flash if you jumped the srs plug. also double check your fuses and the ground on the engine under the thermostat housing. had a similar issue with my car last night
Old 03-17-2013, 03:49 PM
Zen_Life's Avatar
the ground on the thermostat I had to put individual wire connectors on because the folks before me put double female open end connectors on two of them and were barely connected. everything in the distributer is getting power says my dad. and trying two different ECU's tomorrow hopefully. I'll recheck all the fuses again along with the internals of the distributer.
Old 03-17-2013, 03:50 PM
Zen_Life's Avatar
also, no power past the coil inside the distributer, but power to the coil.
Old 03-17-2013, 04:04 PM
Marvin1985's Avatar
Change the coil out
Old 03-17-2013, 04:18 PM
Zen_Life's Avatar
my fault, we are getting power passed the coil to the primary and secondary.
Old 03-17-2013, 04:31 PM
Zen_Life's Avatar
will be uploading a video here shortly.
Old 03-17-2013, 06:33 PM
Zen_Life's Avatar
https://www.facebook.com/photo.php?v...5442256&type=3
Did it this way.
Old 03-17-2013, 10:12 PM
Marvin1985's Avatar
Change your main relay. You can pull your fuel pump relay out then take out 1 spark plug and leave it in the wire and hold it grounded to the valve cover while someone cranks the car. See if the spark is weak(orange). I'm betting your relay is shot or your ecu is.
Old 03-18-2013, 05:12 AM
Zen_Life's Avatar
well a coworker has two ecus that will be tested tonight.
Torothebull
06-03-2014 07:28 PM
Prelude MIke
04-22-2004 07:34 PM
SunkistRex
04-12-2004 10:27 AM
XSSIVE
11-21-2003 06:54 PM
wu tang
16
04-06-2003 07:18 PM
Quick Reply: p06 ecu code 0???
