P/S and GROUND WIRES hp gains?
Honda-Tech Platinum Member
I dont know if this thread belongs here but I remember reading a thread recently about a guy removing a power steering on his del sol or an EJ6 (not sure, but I think it was a del sol) and he gained 7hp to the wheels (he even got dyno charts to prove it). Can anyone link me to this thread?
I've also read that less resistant engine ground wires also add SOME hp.
Anyone have threads related to these? Yes, I've searched already!
Well basically my friends think I'm BSing so I need to shwo them thsoe threads
I don't have the link about power steering, but it's not the first time I've heard of someone making a solid horsepower gain from removing it, my car gained just under five at the greatest point, and a little over two at the peak.
As far as ground wires, you have to consider the fact that the OEM Honda wires are pretty camn good, so there isn't really a whole lot of room for improvement. The majority of aftermarket wires I've dealt with have been cheaply made and actually work worse than the Honda ones.
Re: (Kendall)
go get a bunch of 8 guage wires and connect them to 8 places...throttle body, im, starter, vtec soleniod, tranny, thermostat housing, valve cover, altenator...and that should be good to go. thats what i did smother acceleration, faster starting, smoother idling...
Re: (trooper0641)
removing any parasitic draws from the pulleys will give you some form of gains. P/S or A/C are both driven by the crank, so taking those loads off of it will allow it to move with less effort and thus gaining a couple horses. If you actually think about it, your not really gaining horses, your just setting a few loose that weren't able to make themselves present beforehand.
As for ground wires. Electricity is like water. More pipes to flow through = faster, easier flow. It's just finding where to put the pipes. Experiment with different spots, dyno if you can.
I really don't know
Re: (franken-B)
dont tell the appearence forum that more ground wires are better. Next thing we'll know they will have 100 wire kits for sale. hahaha
I think the ITR forum has dyno sheets comparing earthing systems
1 Post
Re: (JDM EK9)
i worked on my friends car... ac/ps removed and replaced all the grounds, changed oil, tbelt, and a valve adjustment, and timming.. spent little to nothing and it made a MAJOR diffrence.. car pulled so much better.
Well worth it i think.
Re:
I wouldnt trust the ground wires. Import Tuner did a dyno test and switched the stock ground wires on a prelude for the hyperwires(?) that had 5 connections and actually lost 2 or 3 hp.
Re: Re: (DewMota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota »</TD></TR><TR><TD CLASS="quote">i've seen a couple mags do dyno's on replacing the ground wires and they made hp. I'm sure they fudged it up. Also the ac runs off the crank.. enough said</TD></TR></TABLE>
it runs off the crank when you turn the a/c on, when its off its just a pulley that spinning. so if you think the .25hp it may take to run a pulley is worth not having a/c then go for it, and while your at it strip your car to nothing and make it a even crappier car.
Don't Trust Anyone
Re: Re: (AzCivic1.6)
We are pleased to announce that during a recent dyno test for D-Sport magazine, the new A'PEX Super Ground System made an outstanding 8.5 horse power to the wheels. Testing was conducted on a 2004 Subaru WRX STi using XS Engineering's four wheel chassis dynamometer. Previous modifications to the car consist of upgraded intake, downpipe, exhaust, and front mount intercooler. Power output was increased throughout the power band with a maximum gain of 8.5hp at 6000 RPM (400 RPM sooner than baseline max power). This test proves the real world capabilities of the Super Ground System.
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: (DymSum)
if you go to http://www.sunautomobile.com they sell power and ground wires. They make some claims on the site and include dyno sheets to back them up.
