Oxygen Sensor Heater (Check Engine Code 41)??? NEED HELP PLEASE!!!
I recently swapped a JDM B18C R motor into my 2000 SI. However, the harness on the B18 was JDM (backwards of USDM, obviously), so I used my stock B16 wiring harness. I'm throwing check engine code 41, which I discovered is the oxygen sensor heater. What symptoms would I look for with a problem like this/ what would cause this code to be thrown? Also, I can only rev to 6700... I have no clue what the problem could be with either of these things.
Any advice would be greatly appreciated!! Thanks.
Re: Oxygen Sensor Heater (Check Engine Code 41)??? NEED HELP PLEASE!!! (itr590)
check the wires.. 1 of my wire was fried and i got the same code.
Re: Oxygen Sensor Heater (itr590)
As h22bb1 stated check the wires, I had the same code turned out one of the wires was pulled out the plug easy fix.
IF it all the wires look fine then get a new o2sensor for it. 4wire one.
Re: (teamm_AP1)
i just had this problem. check the wires and see if any are fried or disconnected. although mine is turbod so i also had a new map burned for the o2 sensor. shouldn't be a hard ix. took me not to long
