overheating problems
OG triple OG
just started today , i noticed my car getting really hot , and i didn hear my fan....but its comming on after it gets quite hot , cohould it be my fan switch starting to go out??? or my thermo switch , what could it be???? it will get real hot , then it will come down..its wierd
OG triple OG
Re: overheating problems (Racerage1)
it only happens when its in traffic , then it kinda stays at the same temp when im driving the town....but goes down the faster i go......ya it looked lke it was comming on too late
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: overheating problems (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
I have the EXACT same problem...thanks for starting this thread.
Re: overheating problems (boostincoupe)
i'd say bad thermostat
https://honda-tech.com/zerothread?id=698493
https://honda-tech.com/zerothread?id=697338
Re: overheating problems (jwn7)
ok the bottom radiator hose is warm as well as the top one , and my fan is comming on.....what gives.....
this is hella_jdm im on my friends name
Re: overheating problems (TURbb1)
i think your thermostat is workin....tryt wiring your fan to a switch so that its on all the time...if that doesnt work...my guess..its prolly a leaky headgasket
same problem here...i just ordered sum arp headstuds and an oem headgasket
when your gasket is leaking, it leaks exhaust gases into your coolant which makes it boil...and what happens next is similar to what u been noticing, get it?
OG triple OG
i popped open my radiator cap and i had no coolant in there , i know for a fact i havent been leaking any cause i park in a garage , which leads me to believe maybe i have developed a crack in my radiator over the weekend(parked outside in the rain and cant see any leaks)
Re: overheating problems (AREA 51)
Yup, I have a similar problem. Before my car is even warmed up (about 2 minutes after I start it up) my temp needle shoots the the very top H. Then it falls back down when I'm stopped, then shoots way up when I go again. hmm.
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AREA 51 »</TD></TR><TR><TD CLASS="quote">Thermo switch / fan switch or stop doing boostin burnouts in traffic !
aahah when did i do that!!!!!
i blew my head gasket and coolant was not leaking on the ground.its goin in the motor and cooking off from the exhaust temps,replace head gasket and check head for warpage
Re: overheating problems (joecivic93)
I had a similar problem with mine too--after checking/changing all the obvious things--i swapped in a new radiator and its been fine ever since--older honda rads are prone to calcium deposits
Re: overheating problems (HNDAPWR)
i forgot to add in my first post that i also put in a new double core radiator it is not much thicker than a stock single core but has better cooling capacity which means the cooling fan does not have to run as much,at least thats what i was told!
OG triple OG
the headgasket is brand new , only 4 months old.....and im getting no white smoke or anything , for some reason the coolant is being pushed into the resivior tank making it overflow!!!!!
my upper hose is hot hot , like too hot to grab and hold .
and my lower is just warm , i can hold it , does that mean my thermostat is gone??
CHECK UR COMPRESSION...MIGHT BE A SLIGHT BLOWN HEAD GASKET.....OR BLEED UR RADIATOR....TAKE OUT THE THRMOSTAT...=p TRY THOSE ...CAUSE IT HAPPENED TO ME...=T
