Overheating problem..please help.
Old 02-15-2010, 05:47 PM
91EF_Si's Avatar
Default Overheating problem..please help.
Ok so my car started overheating lately, but has gotten worse. Will only overheat during a long period of WOT time and will go back to normal temp in 1 or 2 minutes. I just drove it 2 hours on the highway/local without passing 4k rpm and it didn't overheat at all. I've noticed that both hoses are hard after I drive it for a little while and sometimes the radiator spits antifreeze back in the reservor. Previous owner told me he put a autozone(felpro) headgasket and re-used stock gsr headstuds and tourque them down with a bootleg autozone tourqe wrench.
Could it be a crack sleeve, bad headgasket, etc?
NA ls/vtec b16pistons everything stock.
I've already tried...
New radiator
3 thermostat's
New hoses
Fan is always on
Bled the system for hours
OEM water pump is 10k miles old
Compression test. 225 all across
It's not mixing oil/antifreeze at all
No smoke
I'm lost?
Old 02-15-2010, 05:56 PM
thelate1's Avatar
Default Re: Overheating problem..please help.
Kinda sounds like you might have an air bubble somewhere. Try bleeding the coolant system see if that helps.
ekcoupeh22's Avatar
its probaly the head gasket but if nothing is mixing then i dont know if it would be the head gasket
Old 02-15-2010, 06:04 PM
91EF_Si's Avatar
Already bled the system for hours and still nothing. Lets say after a WOT run, i slowly remove the rad. cap(3rd new one) theres alottt of presure/air? coming out until i completly remove it. It's like air its getting in the system or something. Also water pump is 10k miles old.
Old 02-15-2010, 06:09 PM
Meoshe's Avatar
Leakdown test
Old 02-15-2010, 10:37 PM
Green Lude 93's Avatar
are you losing coolant? sounds like u either have a small leak in your system or your head gasket needs to be replaced. get a hold of a radiator pressure tester. not sure what its really called. You pump pressure into your system and the pressure shouldnt change over 5 min.
Old 02-15-2010, 10:40 PM
open up your radiator cap with the radiator filled to the top then start the car. if the coolant shoots up from the radiator then most likely the head gasket is bad.
Old 02-15-2010, 10:42 PM
91EF_Si's Avatar
^^^Already did both things you just said. Only thing thats left that i haven't done, its a leakdown test.
91EF_Si's Avatar
And i am loosing very little coolant.
Old 02-15-2010, 11:20 PM
infinitypro12's Avatar
How do you know your overheating? Is it possible that your cluster may be confused or misreading? Have you tried another ECU? Is the engine just insanely hot? Whats your oil level and whens the last change you did?
I realize some of those are a little redundant but unless you have zero oil or your electronics are malfunctioning there is zero reason why this is happening.
Old 02-15-2010, 11:34 PM
91EF_Si's Avatar
Exactly what i am saying. Oil change was done 400 miles ago, oil was real clean no weird color or milky. Oil level is always on the 2nd dot. Already tried 2 different clusters. While its "overheating" I can still touch the valve cover and not get burned and top is hot, but bottom one stays warm. Have not tried another ECU yet or tried a different temp sensor(on the head).
91EF_Si's Avatar
Also when the car is "overheting", it still drives strong and doesn't loose any power, missfire, smoke, etc...
Old 02-15-2010, 11:41 PM
Note, I am not expert and I don't gamble a lot but I would put money on a faulty sensor or thermostat.
----Now, I haven't personally tested my civic's thermostat but I remember when I had my 350 in my truck I had overheating issues and my father showed me that you can take the "thermo" off and dip it in boiling water to see if it trips. Granted this is an older engine and I have yet to do research on honda "thermos."
I am assuming that you just see the temp climbing on the cluster?!? If your civic is anything like mine you might as well just starting replacing a bunch of crap until HT comes up with an answer or it works, ha ha. If you remember please post your solution or PM me.
Old 02-15-2010, 11:51 PM
91EF_Si's Avatar
Tried 3 thermostat and did put them in boiling water, and they did open and close properly..so it isn't the thermostat. I guess i'll try replacing the sensor, but I don't understand why it would spit back antifreeze in the reservor. NO bubbling either.
Old 02-16-2010, 02:29 AM
peaseapea's Avatar
I had that exact same problem, man. Twice.
The first time it was simply a bad radiator cap. It mimicked all the
symptoms of a blown HG.
The next time, it was overheating a little more often and had a bad
habit of filling up the reservoir and not sucking the coolant back into
the radiator after the car wasn't running. That time, it was a blown
HG. It also had the stiff / hard hoses from pressure being pushed
into the cooling system..which was also the cause of the coolant
being spit into the reservoir.
Old 02-16-2010, 07:44 AM
91EF_Si's Avatar
Thanks man. I guess thats my problem.
Old 02-17-2010, 01:51 AM
Is this solved?
Old 02-17-2010, 10:20 AM
91EF_Si's Avatar
Nope.
Old 02-17-2010, 02:49 PM
demdem's Avatar
I have the same problem presently, and I cannot find the solution. It only over heat when I really drive the car hard for long. You tired changing the head gasket yet?
Old 02-18-2010, 08:05 AM
91EF_Si's Avatar
No, but everyone is leading me that direction..so i'm pulling the head today. Will update.
Old 02-19-2010, 09:17 AM
demdem's Avatar
well i am doing the same tomorrow too
Old 03-09-2010, 08:33 PM
demdem's Avatar
anything yet
Old 03-30-2010, 03:00 PM
demdem's Avatar
well i found my problem it was the head gasket that was blown
EG92DX
08-08-2013 07:09 PM
ADIZZLE08
Honda Civic (2001 - 2005)
13
05-11-2010 08:15 PM
greenlikematt
10
07-22-2008 06:30 PM
dbman96
11-02-2001 03:48 AM
dbman96
10-30-2001 06:10 AM
Quick Reply: Overheating problem..please help.
