Overheating Problem
Overheating Problem
1. My radiator fan will not come on. My fan is still good, it just wont turn on. Is there a sensor that could be bad that would result in my fan not turning on? Anything that comes to mind, please post. thanks
Modified by 93 EG at 1:38 PM 3/4/2007
Re: Overheating Problem (93 EG)
check ur wirings... specially in the harness.. mine like that and we took off the fan then try it direct it works so we figured it out that the wiring in the connection is bad...
i had this same problem, there's a sensor near the thermostat housing that controls the fan. One of the wires on the sensor came off from corrosion and stuff. Check ur wires around that area.
