Over heating issues
Old 08-12-2015, 07:03 PM
Sneakysol94's Avatar
Default Over heating issues
So I did a build in my 94 del sol with a d16z6. I used a oem head gasket with arp head studs. On first start up it idled kinda weird I thought maybe I didn't bleed the cooling system right so I rebleed it with my spill free cap. Took it on a test drive got half a mile started over heating made it back home, pressure tested the cooling system and found no leaks. Rebleed the system and I noticed the lower rad hose was cooler then the upper. I thought maybe my new thermostate was junk so I replaced it and rebleed it. I noticed I didn't have heat either. Still has the weird idling all the coolant hoses are new and so is the water pump. Any help would be appreciated, could it be that I flipped the head gasket around? No oil leaks I also pulled the spark plugs no sign of coolant on the plugs.
Old 08-12-2015, 07:33 PM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: Over heating issues
no heat? possible clogged heater core. run it, check for a temp difference in the two lines.
Old 08-13-2015, 11:51 AM
Thanks I got it figured out, had a hose on wrong lol
RollTide
Honda Civic (2001 - 2005)
67
08-16-2012 08:36 PM
Schultzie
12-10-2011 05:40 PM
MarkM01
04-10-2011 04:21 AM
94CoupeNY
02-04-2010 03:22 AM
slow91crx
38
10-20-2006 08:29 AM
Quick Reply: Over heating issues
