over heating
Old 06-13-2006, 12:02 PM
Panda hatch's Avatar
Default over heating
I have a 94 civic sedan and every once in a while my car will over heat. Everytime I gas the car it would go down and when I stop it would go back up. This is while i have the heater on also.
Old 06-13-2006, 02:56 PM
DB1_559's Avatar
Default Re: over heating (Alex804)
DOES YOUR fan works and how many miles on the car can be your waterpump but im not sure cause i got the same problem on and off overheating
Old 06-13-2006, 03:32 PM
Slamaccord's Avatar
Default Re: over heating (jdmboi86)
First of check your anti-freeze level.
Check your T-stat.
Make sure your fan is working.
Do a compression check.
If it was your W/P you could be leakiing antifreeze. And if it was seized, your timing belt would of snapped off or shreaded the teeth.
Old 06-13-2006, 03:37 PM
JDMegCoupe's Avatar
engine over heating? yes? How's the radiator? what year? is it still orginal radiator? If so get a new one it'll help, thats what I did on old 93 coupe (sold) Maybe radiator on it is bad, or the coolant.
Old 06-13-2006, 04:27 PM
eg_ferio's Avatar
ive got da same problem da last time guesse whatit is??? ready its my radiator...lol
Old 06-13-2006, 11:14 PM
my civic is a 94 with original radiator, and my anti freeze level is fine so i guess i should do a compression test ?
Old 06-13-2006, 11:31 PM
E46Kid's Avatar
Default Re: (Alex804)
did u check the thermostat?
Old 06-14-2006, 12:29 AM
Default Re: (EkSi)
No not yet.Not really sure how
Old 06-15-2006, 05:18 PM
JDMegCoupe's Avatar
considering it's the original radiator I would just replace it, unless you just want to do a test on whatever and etc if taking to a shop etc guys could charge your up the *** just to test + labor?
But if test fails, the test would be kind of a waste if you're spending money so if you don't mind buying a new radiator no more than but around $120 more or less it might fix the problem if not good luck. Mines costed $100 something not too much-don't remember, auto store. Pretty easy to install yourself as well did it myself first time no problem, looking to buying a new one for my new coupe the re-built is not as effective-seems to be hotter than normal like grab the dip stick burn your finger hot! so yeah well good luck
Old 06-15-2006, 07:56 PM
stock_honda_coupe's Avatar
Default Re: (JDMegCoupe)
Before you spend money, do some tests. Does your fan kick on? How does the outside of your rad look? It should be clean. This is while sitting or at town speeds right? If your coolant looks clean you rad should not be plugged. And I've seen water pump blades basicaly go away. This would explain why reving would bring the temp down. The blades might not be working at like there ment to be.
pyrojeff
10-21-2019 09:50 AM
streetsmart
09-03-2007 01:16 PM
MindX
08-03-2006 07:56 AM
HiMilerCivic
11
04-19-2005 07:17 PM
IM ALL BOB
07-08-2001 05:47 PM
Quick Reply: over heating
