Over filling of oil by the Garage!
I have a 93 Honda del sol. When I bought the car the past owners just had a fresh Tune-up done to the car. Their garage over filled the motor by a quart. I removed a little over a quart of oil. After putting on about 1000 miles I had my father-in-law’s mechanic look the car over and had him change the oil. I never thought to check the level of the oil when I picked up the car. After about a week I looked a little closer at the bill, it state I was charged for 5 quarts of oil. I then checked the oil level, and sure enough it had 5 quarts. I was told it would not be a problem as oils today do not foam. Is this true or is it really bad for the motor?
Thanks for the feedback.
Re: Over filling of oil by the Garage! (Xmar)
drain some of that out man, and start changing your oil yourself.
thats shitty when a place would do that.
at my work if we overfill, we have to drain it out.
if anything is wrong with it i would definatly raise hell at the place that did your oil change. they must be some real tools there to not check the oil level after changing the oil
Re: (b16ej1lsd)
Do you have problems to start the car in the morning, and is your idling everytime good ?
An oil overfill will give you an important oil return in the intake, and then make your car running bad.
Anyway, keep the right oil level.
Your car should be fine. A quart over isn't a whole lot if your just driving it like your everday car.
Now, the 8 quarts that were in my y8.....whew, that car got hydrolocked! Either my dipstick had a clog that prevented oil from getting to it or my oil was hiding outsomewhere but I checked 2 separate times about 3 hrs apart and both times my stick said '0' oil...
anyways, you should be fine.
this happened with my volvo, i usually change my own oil but i let my mom borrow it.... they put in a quart too much plus a quart of "oil additive"
oil had filled the valve cover....and worked its way onto the timing belt...
l
l
Mr. Indecisive
Re: (honda_racing101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_racing101 »</TD></TR><TR><TD CLASS="quote">4.2 ^</TD></TR></TABLE>
oh yeah
oh yeah
techsynthesis
01-13-2008 09:45 PM
