Out with the old... In with the new
Old 08-20-2002, 01:50 AM
dnt94civic's Avatar
Default Out with the old... In with the new
well, I have been wanting to replace my rear Suspension Techniques 19mm sway bar for a 22mm ITR sway bar, and I finally saw a good deal on a ITR rear sway bar with gsr lcas and the beaks kit too for only $150 bucks.
Installation was pretty straight forward. At the same time, I installed some Energy Suspension bushings on the rear gsr lcas, which have been in my closet for almost 2 years.
Here are the pics:
http://community.webshots.com/album/47649151FHibRV
Afterwards, I took it out for a test driive. All I can say is that I am extremely happy with the outcome. I can easily take the off ramps from my freeway at 45+ mph. The car feels more nuetral now. Now I am deciding if I should upgrade the front sway bar too.
Oh btw, I also wanted to show you guys my painted calipers that I painted black. Didn't want it to be really noticeable, and I couldn't stand the way it use to look, very dirty.
Old 08-20-2002, 05:47 AM
bullz's Avatar
Default Re: Out with the old... In with the new (dnt94civic)
Looks sturdy. I planning on gettting the Comptech sway tie bar combo soon. Hopefully it's good.
Old 08-20-2002, 07:18 AM
DevinW's Avatar
Looks nice...my brother also painted the calipers black for me. I like it as well!
Old 08-20-2002, 07:30 AM
cre18's Avatar
Default Re: Out with the old... In with the new (DevinW)
Beaks Kit
Old 08-20-2002, 07:42 AM
willyboyK20's Avatar
Default Re: Out with the old... In with the new (cre18)
nice
Quick question. Would i have to drill a extra hole with the beaks kit on a 97 civic or can i use the stock holes on the subframe?
TIA
Old 08-20-2002, 02:47 PM
dnt94civic's Avatar
Default Re: Out with the old... In with the new (willyboyD16)
I think you will need to do some drilling.
Old 08-20-2002, 04:56 PM
slooowDX's Avatar
can you use GSR LCA's w/ stock EG DX drums in the rear?
Old 08-20-2002, 04:59 PM
JV
Who?
JV's Avatar
Default Re: Out with the old... In with the new (slooowDX)
Yep, LCA's have nothing to do with the braking system...
Old 08-20-2002, 05:02 PM
slooowDX's Avatar
Default Re: Out with the old... In with the new (JV)
kooooool thanks
Old 08-20-2002, 05:26 PM
KRiS1's Avatar
The bushings you installed on the integra LCA's, were they from a civic kit or the integra kit?
[Modified by POS Hatchback, 9:23 PM 8/20/2002]
Old 08-20-2002, 06:23 PM
PatrickGSR94's Avatar
If you upgrade the front bar, your car will once again be less neutral (more tendency to understeer) than you have it right now. If you like the way it is now, I would leave the front sway bar as is.
[Modified by PatrickGSR94, 9:23 PM 8/20/2002]
Old 08-20-2002, 08:35 PM
Eee Pee's Avatar
Default Same rear lower arms
Same rear lower arm bushings. Tighten up yo' rear.
Old 08-20-2002, 08:36 PM
Eee Pee's Avatar
Default Awwwl right, first post.
I got nothing.
Old 08-20-2002, 09:19 PM
marty's Avatar
Default Re: Awwwl right, first post. (E Prepared)
you stole my thread title from app/cosmetics !!!
just kidding. nice suspension there.
Old 08-20-2002, 10:36 PM
2000_Civic_Si's Avatar
Where to buy beaks kit? to put a ITR 22mm sway bar on Civic Si?
Old 08-21-2002, 12:26 AM
dnt94civic's Avatar
Default Re: Out with the old... In with the new (PatrickGSR94)
If you have the gsr lca's, then you will need the integra rear control arm kit from Energy Suspension.
The lower control arms for the 5th gen and del sols have different bushings which are smaller.
Do you have civic lca's, because I have an extra set of Energy Suspension bushings for a civic.
For the beaks stuff, go hereL
http://www.beaksproducts.com
[Modified by dnt94civic, 1:26 AM 8/21/2002]
Old 08-21-2002, 05:40 AM
xtrafastcivic's Avatar
is that rust ?? looks bad
Old 08-21-2002, 08:09 AM
KRiS1's Avatar
where can I get the ES LCA bushing set? Most places I found only sell the entire master bushing kits
Old 08-21-2002, 08:13 AM
owen_the_soyboy's Avatar
Default Re: Out with the old... In with the new (POS Hatchback)
http://www.summitracing.com
zippo1130
15
01-15-2008 07:45 PM
DeDonDeRosa
07-26-2003 06:26 PM
Ilouisell
06-04-2003 09:24 AM
ArizSun21
01-04-2003 01:07 PM
Quick Reply: Out with the old... In with the new
