Orthia or CRV B20 motor? how do you tell the difference visually?
1. just want to see if anyone knows how to tell difference between a JDM Orthia b20 block from a JDM CRV b20 block? how can i tell?
(i have a 97 JDM b20 block, but i dont know if it came from an Orthia or CRV)
2. also, what head does an Orthia have?
(i know the CRV block comes with either P75 or P8R head)
Re: Orthia or CRV B20 motor? how do you tell the difference visually? (MKEK9)
dude...i allready told you this..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">
JDM
96-98 Honda Orthia
143 HP, 132 ft/lbs TQ
9.2:1 compression
96-98 Honda Step Wagon
123 HP,133 ft/lbs TQ
9.2:1 compression
99-00 Honda Step Wagon
134 HP, 136 ft/lbs TQ
9.6:1 compression
96-98 Honda CRV (two variants)
128 HP, 136 ft/lbs TQ
8.8:1 compression
9.2:1 compression
99-00 Honda CRV
148 HP, 136 ft/lbs TQ
9.6:1 compression
96-98 Honda SM-X
128 HP, 135 ft/lbs TQ
8.8:1 compression
99-00 Honda SM-X
138 HP, 137 ft/lbs TQ
9.6:1 compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">well...the 96-98 Orithia came with a P8R head...the 96-98 Step Wagon also came with P8R head..the 96-98 CRV came with either P8R heads or P75...so its either a SM-X, CRV or 99-00 Step Wagon..</TD></TR></TABLE>
since you have a P75 head...YOU DONT HAVE AN Orithia
JDM
96-98 Honda Orthia
9.2:1 compression
9.2:1 compression
9.6:1 compression
8.8:1 compression
9.2:1 compression
99-00 Honda CRV
9.6:1 compression
96-98 Honda SM-X
8.8:1 compression
99-00 Honda SM-X
9.6:1 compression
Re: Orthia or CRV B20 motor? how do you tell the difference visually? (B18CivicEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">dude...i allready told you this..
since you have a P75 head...YOU DONT HAVE AN Orithia</TD></TR></TABLE>
thanks, just wondering if you know what head the 96-98 Step Wagon have?
(i noticed it has the higher compression ratio (9.2.1) according to your chart, but it has the 123 HP and 133 TORQUE resembling lower compression, just wondering if that is a typo on the chart?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">not a type-o....numbers were taken from japan's honda website</TD></TR></TABLE>
thanks, so just to make sure...according to your chart...
96-98 step wagon has P8R head?
99-00 step wagon also has P8R head?
(since they both have higher compression of 9.6.1 and 9.2.1)
not sure but your head is a 96 cast which was from a 97 car, so i dont see why it matters..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">not sure but your head is a 96 cast which was from a 97 car, so i dont see why it matters..</TD></TR></TABLE>
sorry, because now i am getting very curious....
if the 99-00 step wagon <U>may</U> have a p75 head w/ high compression (9.6.1), does that mean that there are some b20 motors with p75 head that also has higher compression?
(so... not only P8R heads come with higher compression, but some P75 head motors also have higher compression?)
thanks in advance!!!
Crazy Honda Guy
I know this is a bump on this thread, but though i'd add some insight
That is actually not correct.
I know for a fact that the 1999 Model Honda Orthia was available with a P75 head which is a higher compression model, as i just installed one into my EK hatch.
I don't know if there is even a way to tell if there is a difference between the engine between the Orthia and the CRV? I'm thinking they are the same.
Modified by Deetz at 4:31 AM 3/27/2008
Crazy Honda Guy
Re: Orthia or CRV B20 motor? how do you tell the difference visually? (builtbynotorious.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builtbynotorious.com »</TD></TR><TR><TD CLASS="quote">wow i have never heard of that car before is new </TD></TR></TABLE>
New? Not at all, it 1st came out in 1996 with 1.8L and the lower compression B20B, then it got revised with a newer look and more power in 1999. Last year of production was 2002. Many people have not heard of it because it came over seas only. It was based on an EK sedan chassis.
Here's an interior shot:
Re: Orthia or CRV B20 motor? how do you tell the difference visually? (Deetz)
Wow Deetz, I always thought that was a custom intake mani. GOod info to know man.
Crazy Honda Guy
Re: Orthia or CRV B20 motor? how do you tell the difference visually? (VN712)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VN712 »</TD></TR><TR><TD CLASS="quote">Wow Deetz, I always thought that was a custom intake mani. GOod info to know man.
ha ha, its actually found underneath the hood of every North American model CRV in 1999 and 2000. Its design to help mid range torque needed to move a heavier vehicle 4cly suv.
Here's a pic of a local 2000 model crv
felipe69
10
04-12-2009 02:33 PM
SinsEvil666
06-22-2008 12:56 PM
