opinions...check this out and leave some input please.
Guest
Posts: n/a
i can get a driver side upper mount for an EG form this place:
http://www.innovativemounts.com/
for about 90$ urethane insert by the way. or should i just go with a hasport?
* B A N N E D *
Re: opinions...check this out and leave some input please. (david)
make sure the urithane is solid, i had some urithane mounts from avid racing, and the urithane was only two 1/2 inch thick plugs in the ends, with a steel sleeve for the bolt to go through, it ended up sagging and wallering out the urithane over a year.
hasport all the way way more sturdy and if you sell the car to some other inthusiast it is always good to have the cream of the crop in parts to get the most money for the car
Guest
Posts: n/a
Re: opinions...check this out and leave some input please. (dajman94)
i'm never selling this car...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 »</TD></TR><TR><TD CLASS="quote">make sure the urithane is solid, i had some urithane mounts from avid racing, and the urithane was only two 1/2 inch thick plugs in the ends, with a steel sleeve for the bolt to go through, it ended up sagging and wallering out the urithane over a year.</TD></TR></TABLE>
good point. hasport it is then.
RacerXI
07-10-2003 08:45 AM
