Omni test pipe question
Old 08-12-2006, 07:36 AM
GetawayInMoscow's Avatar
Default Omni test pipe question
Okay so anyone who has seen this thing knows it's adjustable. But my question is:
One you have it adjusted, should it be welded? The reason I ask is because I'm trying to quiet my exhaust down some, and though I know a test pipe contradicts the whole quiet exhaust thing, I feel I still have options...
So if I weld it will it be quieter due to less leaking? I guess I could stainless steel tape it and see if that works...
Old 08-12-2006, 09:10 AM
Deckard's Avatar
Default Re: Omni test pipe question (GetawayInMoscow)
I have not noticed any leaking on mine. I think when it gets hot, the metal expands so it really does not leak.
Old 08-12-2006, 09:17 AM
Sean @ ESG's Avatar
you want to quiet down your exhaust by removing the catalytic convertor? Or is it already out? Because that will only make it louder. The test pipe wont change the decibal's at all. If anything it will be louder.
Old 08-12-2006, 10:25 AM
benztech's Avatar
Default Re: (banzai msg)
my test pipe hasnt leaked at all and honestly it really wasnt that much louder than the cat was, no bad smell either.
Old 08-12-2006, 12:12 PM
iheartjayDem's Avatar
the skunk 2 one will bolt right up.
you can pick it up for a 100 bucks at jhp.
helped on my friends D16Z6
Old 08-12-2006, 12:32 PM
EGhatch33's Avatar
Default Re: Omni test pipe question (iheartjayDem)
u can weld, but really it shouldnt leak, and soon after u have installed it carbon build up should seal it. weld it if u want.
solesthatgo
04-09-2010 04:51 PM
SiYouLater
Acura TSX
01-11-2009 03:50 AM
EGhatch33
05-01-2006 09:37 PM
comptechgsr2000
Honda S2000
04-27-2002 03:48 PM
BlackGSR
08-19-2001 06:34 AM
Quick Reply: Omni test pipe question
