Omni Power Quicklutch Master Cylinder
hi everybody im canadian so my english its not so good,i have a civic EG and i am very interested on this product
is it a good think or not?
thanks
thanks
Re: Omni Power Quicklutch Master Cylinder (pine_apple45)
they had some major issues with the early ones, the seals would be shot and it would stop working. I dont know if they have fixed it yet... i would search and see if anything has changed
Re: Omni Power Quicklutch Master Cylinder (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">they had some major issues with the early ones, the seals would be shot and it would stop working. I dont know if they have fixed it yet... i would search and see if anything has changed</TD></TR></TABLE>
the issue has been resolved, and someone has had done a product review on it already. it was pretty recent, but searching should yield positive results.
Re: Omni Power Quicklutch Master Cylinder (pimp civic)
I actually helped a buddy of mine install one of those this weekend. I don't know how they stack up next to other clutch master cylendars but the action of the Omni quick clutch is crazy. The clutch travel is about 15 - 20 mm and you don't have to press it down all the way to engage the clutch. Super fast shifting. I am going to be buying one soon.
HT Order of Merit
Re: Omni Power Quicklutch Master Cylinder (TahitianEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TahitianEG »</TD></TR><TR><TD CLASS="quote">I actually helped a buddy of mine install one of those this weekend. I don't know how they stack up next to other clutch master cylendars but the action of the Omni quick clutch is crazy. The clutch travel is about 15 - 20 mm and you don't have to press it down all the way to engage the clutch. Super fast shifting. I am going to be buying one soon. </TD></TR></TABLE>
I've heard the same. The pedal actually sits lower than stock.
Re: Omni Power Quicklutch Master Cylinder (JDM_Ej)
i have it on my type r swapped del sol
the first version was messed up and kept breaking, but the new version that they sell works perfect
it require less pedal travel, seems to remove the notorious 3rd gear grind at high rpm
and it seems like the power is getting to the ground faster then before
i used to chirp third with my tires air down a bit, now even with them air downed i spin alot in third
Re: Omni Power Quicklutch Master Cylinder (digital sol)
ok so if its this good i guess the next question is who or where sells these and whats the price?? my hatch is about to go back together and my rps clutch has already claimed 3 factory slave cylinders.. anybody making slaves?? and ill buy a master.
