OMG.. my lugnut is stuck!
Old 11-06-2003, 10:13 PM
ieatrice's Avatar
Default OMG.. my lugnut is stuck!
ok, today i was putting on my new si rims.. i started with the front and worked my way to the back.. i was about to put in the last one (rear/right) and one of the lugnuts was stuck so i put the lugnut remover thingie on it and used my foot to try and loosen it up.. then all of a sudden the lugnuts was in the middle and it turns.. but it won't tighten nor loosen.. it's somewhat stuck in the middle.. how can i get this lugnut off?!! btw, would it be safe drivin around w/ only 3 lugs?
Old 11-06-2003, 10:17 PM
99blackcivicSi's Avatar
Default Re: OMG.. my lugnut is stuck! (ieatrice)
i say kick that ****** till it comes off or breaks the stud i wouldn't recomend driving on it a lot just do till you can get a new stud and nut get it ASAP saftey first now
Old 11-06-2003, 10:20 PM
Philip's Avatar
Default Re: OMG.. my lugnut is stuck! (99blackcivicSi)
you will probably have to break the stud off/get a new stud pretty soon. next time torque down properly, or don't let shops torque down to tight. I broke two like that. Also it won't hurt to ride around on 3 studs for a while till you get another one, especially in the back
Old 11-06-2003, 10:24 PM
Default Re: OMG.. my lugnut is stuck! (Philip)
i have a problem with people that torque down lugs they do it on the ground and they don't get a proper seat to the hub and that leaves them to move around a little bit and i don't trust that anymore. My wheel fell off in front of my house the other day and fucked up my fender from getting improper seat on it so do it up in the air with teh car in gear and the E brake engauged. don't half *** on stuff like that because that is the lifeline of your car.
Old 11-06-2003, 10:28 PM
ieatrice's Avatar
how much would this cost me? o.O i'm just a poor college kid getting through life.. sniff sniff
Old 11-06-2003, 10:31 PM
mycivicstoo(s)low's Avatar
A lugnut? Or a new stud? Neither is all that expensive. Especially since you only need one.
Old 11-06-2003, 10:32 PM
Default Re: OMG.. my lugnut is stuck! (mycivicstoo(s)low)
5 bucks at most at a parts store
Old 11-06-2003, 10:36 PM
ieatrice's Avatar
thanks for all the help guys.. i'll get it fix asap >
Old 11-06-2003, 11:12 PM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the help guys.. i'll get it fix asap &gt;</TD></TR></TABLE>
dude tighten it back up...chances are its rust/dirt in the way...just get some WD-40 or simple bolt loosener and squirt it all over the nut til its drenched ....haha
then wipe it clean, and spray it again then loosen it.
keep us posted bro.
Old 11-06-2003, 11:18 PM
Default Re: OMG.. my lugnut is stuck! (CleenSi)
He said it turns but doesn't tighten or loosen. It just spins freely. He got it loose.
Old 11-06-2003, 11:57 PM
Mike_C's Avatar
studs are cheap and very easy to install. while you're at it buy a canister of anti-seize.
Old 11-07-2003, 12:36 AM
gaydm.accord's Avatar
the stud no more than 3 dollars its pretty simple and worth the learning experience do it yourself and in the future when installing removing rim remove/install in diagnal pattern criss cross and another note when removing and loosen it up on the floor but get it a little higher when taking the bolt off dont be lazy i broke mine taking it off on the floor too much weight on the stud
Old 11-07-2003, 02:18 AM
Colorado <3
918-Hatch's Avatar
Default Re: (gaydm.accord)
Get it fixed yet?
Old 11-07-2003, 02:28 AM
Default Re: (Billy Blue Hatch)
Lol, it's only been four hours.
Old 11-07-2003, 03:29 AM
93CivicSI's Avatar
Dremel tool & Cutoff disc
Old 11-07-2003, 08:05 AM
Philip's Avatar
Default Re: OMG.. my lugnut is stuck! (93CivicSI)
you may be able to replace the stud yourself. you definitely can if you can pull the hub. i had to bring mine to the shop
Old 11-07-2003, 10:03 AM
Global Moderator
Jimmy's Avatar
i did the same thing..
except i havent fixed mine.
Is there anyway that when you do this you can strip the threads thats in the hub so you haft to buy a new hub?? is this true? could anyone post a DIY?
Old 11-07-2003, 11:28 AM
ieatrice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleensi &raquo;</TD></TR><TR><TD CLASS="quote">dude tighten it back up...chances are its rust/dirt in the way...just get some WD-40 or simple bolt loosener and squirt it all over the nut til its drenched ....haha
keep us posted bro.
?</TD></TR></TABLE>
that's the thing.. it spins loosely both ways.. it's just.. STUCK!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">the stud no more than 3 dollars its pretty simple and worth the learning experience do it yourself and in the future when installing removing rim remove/install in diagnal pattern criss cross and another note when removing and loosen it up on the floor but get it a little higher when taking the bolt off dont be lazy i broke mine taking it off on the floor too much weight on the stud</TD></TR></TABLE>
gotcha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Billy Blue Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Get it fixed yet?</TD></TR></TABLE>
i posted this last night.. and i just woke up. *yawn*
thanks for all the help guys.. i think ima head to kragens now and get a new stud and some wheel locks while im at it.. since there's a bunch of theifs where i live. RAWR! bbl.. laters. thanks again for all the help everyone!
mortificationrock
14
08-01-2010 05:21 PM
misha
14
08-27-2006 08:49 AM
ZexyAccord
Honda Motorcycles
13
06-28-2006 10:34 AM
97LXAcc0rd
08-29-2005 08:06 PM
B18EG6
04-06-2003 10:40 PM
Quick Reply: OMG.. my lugnut is stuck!
