Oli problem
Oil problem
I have ls motor in 94 cx, and change motor oil every 2500~3000 miles but some time my oil level is too low and some time need to put some oil about 1500mile (put 3Q of oil) and it looks like leaking from the oil pan but im not sure. is any body have idea about my oil problem.
Re: Oil problem (supercivic B18B1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supercivic B18B1 »</TD></TR><TR><TD CLASS="quote">I have ls motor in 94 cx, and change motor oil every 2500~3000 miles but some time my oil level is too low and some time need to put some oil about 1500mile (put 3Q of oil) and it looks like leaking from the oil pan but im not sure. is any body have idea about my oil problem.</TD></TR></TABLE>
claen yuor egnine bya adn wacth fro laeks.
paece
paece
Re: (supercivic B18B1)
it could be you oil pan gasket..i had to change mine because of that....but make sure you get it sealed right, or it will leak again....or it could be a seal that is leaking...i know that they sell this dye that you can put in your oil, and shine a blacklight on it and you can see exactly where the leak is coming from...good luck..the gasket is cheap to fix, but not the seal(s)...good luck!
