Ok I've ran out of ideas with my setup...
installed vtec Y8 and turbo
new ecu (chipped for 450cc and Z6 Head)
new timing belt
new head gasket
new head bolts
everything torqued to spec
OBD1 to OBD2 conversion MSD conversion harness for the distributor
resistor box
450cc injectors
= car wont start/cranks but no start
it sparks also.
giving me check engine light and makes a click noise after I turn the key on position but not fully on. Pretty sure it's because of the following reasons.
My o2 sensor isn't plugged in however its in the exhaust manifold. I need a new one or (20mm wrench to take it out of my old manifold)
that and the vtec solenoid are not hooked up.
I am not using e-manage because blackcrx told me just to use the ecu.
I have a pressure gauge it says around 50 psi when I try and start. it
If you guys come up with good advice just tell me, I would like to hear it.
Thanks!
new timing belt
new head gasket
new head bolts
resistor box
450cc injectors
it sparks also.
Thanks!
Re: Ok I've ran out of ideas with my setup... (dj_zyx)
if it cranks with no fire your either not gatting gas air or spark check pulgs wires dizzy pull your fuel rail and see if your injectors spray just hit your basics youll get it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_zyx »</TD></TR><TR><TD CLASS="quote">
I assure you that I could unplug my O2 sensor and VTEC solenoid and the car would start w/out hesitation. Definately neither of those.
Re: Ok I've ran out of ideas with my setup... (5_Lug_B)
sounds like something is clicking after i put the ignition on full hut not start
than th engine check light comes on
the fuel pump is coming on
when i pulled the injectors out before i didnt see any gas coming out from the tip
there DSM black top 450cc injectors...
im not sure if thats the cause but why wouldnt gas spray out of the tips( could be wrong though and dont know how to check that)
did you use the resistor box for the dsm injectors?
take a plug out put the spark plug wire on it and hold it close to the VC and see if it sparks
and if you did hook up the resistor box for the injectors then crank it for a bit pull a plug out and sniff the plug and if it is gassy smelling then your not getting spark but your getting gas and go from there
Donkeylips87
02-19-2012 06:10 PM
Vash121991
02-05-2012 07:59 PM
Boosted_curse2
13
07-14-2008 06:13 PM
JDM_EK_wanabe
04-09-2008 08:49 AM
