oily air filter-d16y
Re: oily air filter-d16y
The crank case vent on top of the valve cover that goes to the intake tube will have small amounts of oil go threw it and it will end up on the air filter. This is normal especially for an older motor with higher miles.
i spot some leakage around distributor. does the intake suck that oil vapour while engine hot? do i need to change the air filter after fix that distributor leak?
I just worked on a girls Jetta, She use to own a old oldsmobile that took like 7 quarts of oil...well she put that much in her jetta. That thing was shitting so much oil through the intake ahahah.... You didn't do this did you?
fireant
21
11-09-2008 07:55 PM
