oil spill in my engine bay! ;[
BANNED
i have a 99 ex and i removed the valve cover the other day to paint it. i did NOT replace the valve cover gasket and now, i discovered that my car threw up oil all over the place. it is also still leaking. im going to change the gasket but how do i make sure it is sealed correctly?
also, to check oil levels, how do yo uknow when youre really low. id say the oil is up to where the 2 dots is and thats it. is it safe to just dump a quart of oil in and thats it? thanks guy ;[
ps, can i use simple green and spray on the block etc
Re: oil spill in my engine bay! ;[ (VALENTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VALENTINE »</TD></TR><TR><TD CLASS="quote">i have a 99 ex and i removed the valve cover the other day to paint it. i did NOT replace the valve cover gasket and now, i discovered that my car threw up oil all over the place. it is also still leaking. im going to change the gasket but how do i make sure it is sealed correctly?
ps, can i use simple green and spray on the block etc</TD></TR></TABLE>
check your dip stick to see how low it is.. and yes if your low on oil dump a quart in
BANNED
Re: oil spill in my engine bay! ;[ (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">check your dip stick to see how low it is.. and yes if your low on oil dump a quart in</TD></TR></TABLE>
how do u know if yorue low
the dots?
the dots?
to make sure the gasket is sealed use a new gasket and honda bond. You can definietly use simple green. My motor looked like crap, but now it looks new. Make sure you clean off the simp green so that it doenst mess with the finish on the block
the dots?</TD></TR></TABLE>
lower dot? you should be fine at higher dot. add as much oil as needed. keep checkin' dip stick and wipin' till you reach tha higher dot.
_taF
_taF
BANNED
Re: oil spill in my engine bay! ;[ (tallazzFilipino)
damn do yo uneed that honda bond to seal it?
all i did was get a new gasket and i closed it
i think the main problem is one of my bolts dont tighten like before therefore causing the leak.
wish me luck guys, well find out tommorow.
Re: (jtchinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtchinoy »</TD></TR><TR><TD CLASS="quote">i must be lucky, i've removed my valve cover like 20 times and it hasn't leaked yet, original gasket too.</TD></TR></TABLE>
Same here...but im ordering a new one anyways since i just did my timing belt 3Kmiles ago. i just forgot to order the valve cover gasket when i ordered the parts to do my timing belt from HondaAutomotiveParts.
Re: (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">1500 posts and how do i chek my dipstick......................... </TD></TR></TABLE>
since when does,
the post count = level of knowledge?
moron
since when does,
moron
Re: (G2 Speed)
since when does,
moron </TD></TR></TABLE>
yeah G2 Speed has 1700 and he can't even remember his name jk
since when does,
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">well whats hewasting his time posting on chances are he doenst sell things he dont know what hes selling </TD></TR></TABLE>
WTF did you just type???
Re: (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">yeah G2 Speed has 1700 and he can't even remember his name jk</TD></TR></TABLE>
Seriously, that's not funny.. I have issues ... All just ask you everday over msn
How much wood, could a wood chuck chuck, if a wood chuck, could chuck wood!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">WTF did you just type??? </TD></TR></TABLE>
I translated it don't worry
keilux
53
08-17-2009 05:43 PM
90CivicDaily
12
05-04-2008 10:12 AM
