Oil problems with my 96 EK hatch????
i recently changed my oil for my ek hatch and the engine is stock i put 3.5 quarts of oil and waited about an hr for the oil to settle when i check the dip stick it read nothing. it was dry as a bone so i added another .5 quarts and i got a little change but still not normal... does this happen to anyone else....... what could the problem be.... if you have am info let me know thanks
Re: Oil problems with my 96 EK hatch???? (CB7VTEC)
If you weren't on level ground as CB7VTEC said that could cause some issues. But the D16Y7 only takes ~3.8qts, so 4 is more than enough. Should be up to the second hole.
Re: Oil problems with my 96 EK hatch???? (RaceMyHatchBack)
shouldve be fine w/ the amount of oil you added, as stated above.
make sure the car is on level grounds, let the motor run for a few, and check oil level. should be ok. goodluck
that might have been the problem cause i live by hills thanks guys esp for the extra advice i thought that it only too 3.5 but now i know its 3.8 thanks again
Killercocopuff
21
12-20-2011 01:39 PM
Frost7177
11-14-2008 12:53 PM
