Oil Pan Leak
Old 02-02-2012, 01:41 PM
seantobin5's Avatar
Default Oil Pan Leak
Hello, I have a problem with my oil pan. The bolt is stripped and I was planning to do a time sert on threads but a few mechanics I called told me that there's a possibility that it might be cracked because I have an aluminum pan. So I have somebody that's willing to give me a steel pan from a CX to put into my HX. But I'm not sure if that will be compatible because the HX has the aluminum pan... Any help would be great! Thank you!
Old 02-02-2012, 05:29 PM
EK9
Dc4LsTeG's Avatar
Default Re: Oil Pan Leak
Look to see if its cracked. It probably isn't I'm sure that little bolt will strip before it cracks your oil pan
Old 02-02-2012, 07:12 PM
civicjunkie17's Avatar
Where is it leaking from?
Old 02-02-2012, 07:19 PM
k94cvtec's Avatar
bump
Old 02-02-2012, 07:20 PM
EK9
Dc4LsTeG's Avatar
^^why are you bumping this?
Old 02-02-2012, 07:50 PM
k94cvtec's Avatar
why not?
Old 02-03-2012, 07:44 AM
seantobin5's Avatar
I can't really tell if it's cracked or not. The bolt is glued in with Honda Bond right now and that's where it's leaking from. I'm wondering if a steel pan would fit on a D16Y5 engine because I'm tempted to just replace it to save me a lot of trouble in the future with the time sert in case it doesn't work out.
Old 02-03-2012, 09:06 AM
EK9
Dc4LsTeG's Avatar
How is replacing the oil pan gonna allow you not to use a time sert or something? The block is stripped not the pan
Old 02-03-2012, 09:12 AM
seantobin5's Avatar
I'm 100% certain it's the drain bolt on the pan. I'll take a picture of it later but Colorado snow kinda has me locked in the house.
Old 02-03-2012, 09:17 AM
Mitchness's Avatar
And here everyone thought you meant one of the mounting bolts. If the drain bolt is stripped just got to Napa/Oreilly's/Autozone and buy a new one. The drain bolts are designed to strip out before the pan threads anyway.
Seagull Management
94EG8's Avatar
Originally Posted by k94cvtec
why not?
It's post whoring, nothing more.
A steel Y7 pan will work. You might want to check the oil pickups though and make sure they're the same length.
Old 02-03-2012, 09:23 AM
seantobin5's Avatar
Hahaha I'm glad we're on the same page now! :D How would I check the oil pickup? They should be the same right? I should have this done by next week so I won't have to fill my car up with half a quart of oil a day! :D
Old 02-03-2012, 09:30 AM
Seagull Management
94EG8's Avatar
Check part numbers, I just checked myself, both are the same, Honda part number: 15220-P2A-000 004 001 STRAINER, OIL
Just make sure you use a Y7 oil pan gasket.
Old 02-03-2012, 09:32 AM
EK9
Dc4LsTeG's Avatar
X2 I thought he was talking about mounting bolt
Old 02-03-2012, 10:03 AM
seantobin5's Avatar
Okay cool! Thank you so much for all your help!!
Old 02-03-2012, 11:49 AM
Seagull Management
94EG8's Avatar
Not on an aluminum pan, normally they normally pull all the threads out of the pan.
Old 02-04-2012, 11:13 AM
k94cvtec's Avatar
[QUOTE=94EG8;46796897]It's post whoring, nothing more.
i read the post and just wanted to help the guy out buy bumping is thread so other people will see it at the top of the list. Why do you think im post whoring?
Old 02-04-2012, 11:28 AM
EK9
Dc4LsTeG's Avatar
Cuz you don't bump tech threads. Like he said its considered post whoring and that's against the rules. Why argue?
Old 02-04-2012, 11:56 AM
k94cvtec's Avatar
got it! won't happen again!
Old 02-04-2012, 03:07 PM
98ekb18c's Avatar
+1 the aluminum pan strips 99% of the time before the plug strips. Most steel Honda pans strip before the plug too.
As a temporary solution until you can change the pan you can get an oversize plug at an auto parts store. It's just a bigger plug that's tapered at the end and cuts it's own threads into the pan as it goes in. Just be careful and make sure it goes in straight or it will still leak.
Old 02-04-2012, 11:55 PM
Pickelz10's Avatar
what could happen if you add too much oil to an oil change?
Old 02-05-2012, 12:56 AM
Texas4door's Avatar
Even better, just get a piggyback bolt to avoid messing up the newly cut threads in the future OR use a helicoil and put those threads right back in the pan!
JdmMidWest
02-20-2012 05:20 PM
myessay
02-10-2012 04:22 PM
bopbop93030
12-30-2008 10:02 AM
jonnythan
05-23-2007 11:29 AM
Surreal
03-09-2004 06:49 PM
Quick Reply: Oil Pan Leak
