Oil Light Question
Oil Light Question
my son has a 93 automatic and when he presses the brake the oil light comes on. common sense says change the oil but i checked and its fine. and feedback? -thanks
Seagull Management
Bad oil pressure sending unit, bad oil pump, dent in the oil pan restricting oil to the pickup tube, extremely low oil level. Any one of those will cause the light to come on. Look into, ASAP.
one other thing not mentioned here is if the wire has pulled out of the sensor and is hanging behind the motor it may be touching metal grounding it out when he breaks but i would check out what 94eg8 said if it is still conected
Anthony
