oil leak question???
well i just starte to get a oil leak by the oil filter. i chaged it to a green hamp and still leaking. but for some reason looks like its leaking from the the black box thats behind the block right under the manifold. around that area.. anyone have a clue what it could be?
all ur help would be greatly apprecitated..
thanks...chris
thanks...chris
Could the black can have a rust hole in it ? That's for the breather system.
Or the O ring packing on the can is cracked and leaking.
Your sure it's not the oil pressure switch, it could spray oil up.
Oil leaks from that area are not that common.
Re: (1992Si)
well im gonn take the manifold off in a few and c if its from the can or were.cuz i just noticed theres some red gasket sealent on the can so could be that.
and also gonna check the oil pan too.. thanks.guys
TurbothisLS
02-11-2002 01:00 PM
